1 - 20 of 21 Posts
Selling my P1 set up, wanting to go D1 or Turbo.
Keeping my cam, which is better to go with?
Cam Specs currently, Anderson Ford F-42 Blower Cam
[email protected]: 258 Exhaust: 262
@.050 202 206
Lobe Lift: .298 .298
Gross Valve Lift: .536 .536
Can I run turbo with a mild cam such as this?
Or should I just buy a D1
orrrrrrrr, ditch the cam and blower and go turbo?
Yeah, but with that cam will it kill spool? Like I said it's a milder blower cam.
BUMPZ. I'm about to turbo this beast. Need a second opinion on if this cam is safe and non-turbo spool slaughterhouse.
You cant tell me nobody knows about cams on here!
Any blower cam will hurt turbo spool. Might make okay power, but powerband and turbo spool will suck.
I would sell the cams, and blower and go with a turbo. Stock cams will work much better.
D1 would be sick too though.
^--- Somewhere along those lines, but I'm really thinking of going turbo.
Can anyone recommend a good turbo cam? I want an outrageous one. LOPE FOR DAYS.
BYAHHHH!
turbo would be a better route but more expensive. Stock cams will do well with a turbo at a "mild" psi level depending on the turbo size.
I am assuming you'd be going on3 kit?
Discussion Starter #10
Yes, On3 seems to be the best bang for the buck. Talked with the guy who built my motor. Sorry I didn't trust myself to put it together, but it said I'd be safe to around 700ish crank HP. So I'm gonna shoot for the 650rwhp-ish w/o spraying it.
Hoping for a low 10 sec 1/4. I want a quick spool, therefore I want a cam that won't restrict spool time.
BYAHHHH!
stock heads with a mild turbo cams an cam springs will be that...A CEA billet 67mm-71mm will net you a 10 second 1/4.
Whats your race weight? auto or stick?
Discussion Starter #12
Performance Automatic AODE 4k stall
3400ish half tank
I do have a full drag suspension set up.
1500$ is steep for an upgrade IMO. 1500$ can buy a really nice turbo and other miscellaneous turbo bits if im not mistaken?
BYAHHHH!
built motor?
street strip car? engine specs? rear end gearing?
Discussion Starter #15
Manley Rods and Pistons - MMR Block900
C&L TB/Plenum
Procharger P1 @13lbs 3 Core Intercooler
Full Suspension
Performance Automatic AODE 3500 Stall
Anderson Ford Custom Grind Blower Cams
31 Spline Moser Axles / Eaton POSI
Anderson Ford Powerpipe
Zex 100 Shot
Ported and Polished Heads / Intake Manifold
3.73 gears
Pypes Violator exhaust
KB BAP
Dual Cobra Pumps
BYAHHHH!
And just wanting low tens? Street strip car?
Discussion Starter #17
It's not a daily driver, but I'd like to cruise around in it, haha. Like to keep it slightly streetable.
I really want to maximize the power out of the turbo without sacrificing drive-ability
BYAHHHH!
Pretty much like me then.
What type of power you looking to make?
1 - 20 of 21 Posts
