1 - 20 of 38 Posts
hi you can call me mater
I want to Cam my car, not an"aggressive" cam but a little more power adder, if esg could read this thread I need your help
Raging Mad Motherfucker
88- FWD AND RWD FLAT TAPPET E8DZ-6250-A
89-95 FWD AND RWD W/AUTO E9SZ-6250-B
89-95 RWD W/MANUAL E9SZ-6250-A
96-01 FWD 3.8v6s F6ZZ-6250-A
184/202 .424/.448 110LCA 105ICL
96-98 RWD 3.8v6s F6ZZ-6250-A
97-04 4.2L
185/194 .443/.445 112LCA 110ICL
99-03 3.8L XR3Z-6250-CA
178/194 .427/.446 116LCA 111ICL
89 Supercoupe Manual
194/202 .448/.457 110LCA 106ICL
89 Supercoupe Auto
192/198 .445/.457 113.5LCA 108ICL
90-93 Supercoupe ALL
94-95 Supercoupe All
214/180 .427/.443 105.5LCA 108ICL
rpm-mustang cam spec
207/215 .493/.495 110LCA 112ICL
212/224 .531/.519 112LCA 112ICL
215/220 .573/.537 108LCA 112ICL
Common camshafts
207/207 .505/.505 110LCA-- budget cam swap with a good flowing exhaust
207/209 .493/.491 110LCA-- budget cam swap with moderate flowing exhaust
207/215 .505/.495 110/2LCA-- budget cam swap with restrictive exhaust
216/224 .507/.519 112LCA- aggressive 4.2L cam with heads, intakes, etc
215/225 .495/.491 112LCA- mild singleport 3.8L poweradder cam
220/225 .538/.521 110LCA- aggressive singleport 3.8L cam
224/228 .519/.514 110LCA - aggressive singleport 4.2L cam
MORANAV6RACING
210/210 .480/.480 115LCA 115ICL "A" CAM
220/220 .538/.538 110LCA 110ICL "C" CAM
SUPERSIXMOTORSPORTS
212/212 .550/.550 1.7 114LCA Stock 3.8 turbos
212/218 .550/.550 1.7 110LCA Stock automatics
218/218 .550/.550 1.7 114LCA 3.8 turbos
218/224 .550/.550 1.7 112LCA Supercharged 3.8, 5-speeds, high stall
224/224 .550/.550 1.7 114LCA Stroker turbo
224/230 .550/.550 1.7 114LCA Supercharged strokers, 10:1
230/236 .550/.560 1.7 114LCA 11:1, big superchargers
Compcams
200/208 .480/.480 112LCA 108ICL 255HR112 44-700-9 89-PRESENT
204/216 .480/.480 115LCA 108ICL 259HR115 44-701-9 89-PRESENT
210/218 .500/.500 112LCA 108ICL 268HR112 44-702-9 89-PRESENT
210/226 .500/.500 115LCA 108ICL 265HR112 44-703-9 89-PRESENT
218/226 .500/.500 112LCA 108ICL 273HR112 44-704-9 89-PRESENT
97-04 4.2L
89 Supercoupe Auto
Common camshafts
MORANAV6RACING
SUPERSIXMOTORSPORTS
Compcams
The thing is I have no idea what those numbers mean
What lift are the stock springs good to? *Not thread jacking*
Cristan
Cam Specs & Effects, duration centerline separation and lift, more on pereformance engine parts
And Greenypoo They're only good til about .480
60 bucks is cheap insurance for new LS1 springs that are good for .570 and you can use the stock retainers and keepers. Don't even have to switch to roller rockers.
Don't be a Jew and save yourself a blown motor.
:bubba: :bubba: :bubba: :bubba: :bubba:
:hug
Yes but if you have LTs and no cats your car will be LOUD!!!! I toasted my old motor that was cammed in my car and I have LT's hi flow cats, and mufflers and the car used to be pretty fricken loud. No with no aftermarket cam the car is quiet!!!
They make the vehicle much louder due to much more exhaust flow and more HP.
I would look at getting a decent cam for all around. Because a smaller cam will give decent gains and good driveability. And then if you want to add a power adder later you can.
I personally have the comp max street strip cam it is 218 int and 226 exh with a .500" lift on both intake and exhaust. It has a 112 LSA. It is a decent cam if you like a rough idle. It has lots of overlap in it and idles rough. It worked great for DD and I even had no problems starting the car in -30 temps in the winter with it. You could go smaller than that if you want. It is up to your goals with the car.
EDIT: since you don't want an agressive one I would go with like a 212 or so on the intake and 218 on exhaust somewhere in there with a 112-114 LSA.
Discussion Starter #10
I want one that will give me decent hp, and a loud exhaust because long tubes and high flow cats will be on in a couple days,i also want it to be my dd, I'm messaging esg hopefully he will get me a Cam
Go with the comp max street strip 218 226 cam. My exhaust was loud with that. The car turned lots of heads when it was idling or just under 1500 rpms sounded awesome!!!
Discussion Starter #12
Did you need a dyno tune?
Comp Max street strip cam... idles rough... that is laughable!!
It did. To me it sounded good. It did not idle so rough that the car barely wanted to run but it idled good. It had a good lope to it and a choppy idle.
And I did not get a dyno tune. I got a email tune with some datalogs.
Exhaust plays a big part in smoothness. An x pipe will give the smoothest idle sound. Where divorced or true duals with no midpipe will give the roughest. That is what I have on my car is divorced duals with LTs, hi flow cats, and mufflers. I had LTs, divorced duals with no cats and it was obnoxious and raspy and very very loud!!!!! But my favorite setup was my LTs and that was it sounded sweet shook the crap out of the floor boards of the car when idling and driving and you could hear me coming from a mile away. Maybe not a mile but it was very loud.
Answers question.
Discussion Starter #18
But I probably will need a dyno tune because bama, won't write a tune for a Cam ugh sucks
There are lots of places that do mail order tunes such as the one ^ or else VMP, or else Trick tuners.
I personally have dealt with Trick tuners and have had great luck and they have been very helpful and very fast response.
1 - 20 of 38 Posts
