If I'm not mistaken, a "lumpy" cam does have a tighter LSA, but this actually decreases the dynamic in cylinder pressure. With more overlap, there's more of an opportunity for the intake charge to leave through the exhaust ports. This is what kills the vacuum on your car, which acts just like a vacuum leak, and gives you the characteristic lope. This increased overlap helps with scavenging and flow, but mainly at much higher RPM's.
And if you're going turbo, keep in mind NA cams are NOT turbo cams. They are closer than supercharger cams are to turbo, but they are not the same. FI cams will tend to have a longer exhaust duration than intake, because they don't need any help bringing the intake charge in due to boost. However they will have the same high speed characteristics as turbo cams, as both NA and turbo like to live on the high end.
But beside the tech writeup, I highly suggest planning out a build rather than "slapping things together." I also do not advise getting cams solely for the purpose of a "lumpy" exhaust. Granted I'm putting in a set of FR500's in mine, but I'm trying to make the motor more blower friendly, and wring out a few extra ponies. The key is it was thoroughly planned and researched.
Hope that helps a little.
