1 - 4 of 4 Posts
Anyone know the proper procedure to adjust stock camber plates on an 86 SVO?
I'm trying to get 4 or 5 degrees neg. Is that much even possible?
This is for an autocrosser on slicks, so, tire wear is unimportant.
If i remember right, you only have 1 degree total movement in the stock plates. If you are looking to add negative camber cheaply, oval the bottom ole of the strut out (away from the strut body) about 1/8-1/4 of an inch depending on the amount of camber you need. i think 1/4" would be around 6* or so.
1 - 4 of 4 Posts
