1 - 6 of 6 Posts
· Wax on, Wax off
So, took the car to the shop today and got new Steering Rack bushing installed (Offset due to the lowering) and a front end alignment. The shop called me sayin that the alignment was off due to the lowering, but they could get it closer to perfect with "Camber Bolts" which were $23 each. I told them go for it.
The shop then told me that the alignment was now perfect on the front. I can even notice the tires are straight insted of showing a toe at the bottom. My questions is; Does it remove my need for Caster Camber Plates?
My understanding is that the plates help with getting the tires aligned after a lowering job. However, these Camber Bolts they added made the alignment perfect... so is there any need for them now?
· Wax on, Wax off
Well good deal then. The Bolts were $46... alot cheaper than plates. The front tires look better now also. They are straight instead of to bottom poking out.
1 - 6 of 6 Posts
