1 - 12 of 12 Posts
i have 01 bullitt heads, complete. NOT FOR SALE YET. i was wondering if there was a diffenence in cam profiles between the 99 gt cams and the 01 bullitt cams? disassembling them now, will do research later, doubtful; that anything will be turned up, thus any info would be helpful.
worthwile to be installed on a stock gt engine?--until one builds a full longblock.
Doc
I knew about the upper intake and the dual TB But I heard somewhere about the lower being slightly larger.
hmm.. I'll have to look around for some specs.
MM's Mad Scientist
That's what I'm sayin'............ The lower, upper, TB, etc. is a completely different set up. The upper actually connects to the lower at the back of the plenum, and the lower also has larger runners than the PI.
Discussion Starter · #11 ·
ok so cams have the same specs between the GT and Bulliitt? i know that the lower and upper plenum and TB and intake themselves are different...but regarding cams....
1 - 12 of 12 Posts
