1 - 2 of 2 Posts
Hey all,
I just got into to a 2014 GT/CS and was looking for some good recommendations for cams to run on the 302. I'd like something pretty aggressive.
The car will eventually be turboed so I'd like something that could potentially work with that future setup.
Thanks in advance for the info!
Rent Asunder!
1. Welcome to MM.
2. Wrong section. This is the old 5.0L pushrod engine section. I'm sure a mod will be by to move this thread to the correct area shortly.
3. Aggressive NA cams and aggressive turbo cams are 2 different animals. Turbo cams will be less responsive and hurt low end torque a bit without much top end gain on an NA engine. Aggressive NA cams will cause reversion and short circuit problems with a turbo. You kinda have to pick a path to go down. I say if you plan to turbo the car in the future, save your money on the cams and put it toward the turbo system.
1 - 2 of 2 Posts
