1 - 20 of 22 Posts
Just installed Modular Head Shop Stage I Blower Cams and a SLP PowerFlo cat-back. I still have to install the dual GT fuel pumps and 60lb injectors then it's off to the tuner.
sounds good cant wait till mines sounds like that
Sounds reeal goood! How many True Blue Bullitt's did they make?? I don't believe I've ever seen one before!
Very nice man, sounds good. If you dont mind me asking, how much did Nick charge for those cams? Did you do springs or anything?
Sounds great and looks even better! I envy your paint lol. Did you do the cams yourself? Also keep us posted on your numbers man I'm very interested in getting cams after I put on my Vortech.
Discussion Starter #11
The cams were $599 from MHS. I bought the Stage I cams specifically so I didn't have to replace the springs or worry about degreeing. I actually tried to degree the cams in the car, but couldn't get an accurate reading on the dial indicator. So I'm glad I went with the stage I. I'm going to build a short block next year, so I'll replace the springs and degree then.
Discussion Starter #12
BTW, Only 723 True Blue Bullitt's made, minus the wrecked ones and the one someone on the forums painted flat black (that was painful to watch).
Thats exactly what I planned on doing. Dropping in some cams without springs or degreeing them. Then building the motor this winter. Cool, good luck on the dyno man.
what power numbers are you expecting man? Im curious how that intake manifold is going to perform (great im sure)
Isn't it a bullitt intake? It came stock on the car. I'm guessing around 465rwhp.
yeah, but everybody else uses the stock GT one. so I am curious what #'s he makes, considering the motors are pretty similar minus the intake manifold
damn sounds badass for just a stage one cam, i wonder how the stage 2's sound
those MHS's sound bad ass......i already have post purchase dissonance from my anderson f-42's sounding stocky......share the #'s when you get em..
Discussion Starter #20
Thank you for the compliments. I'm thinking power will be in the 450ish range. It dyno'ed at 407hp before the LT headers, mid-pipe, cat-back, or cams. The Bullitt intake certainly makes a difference. When I dyno'ed the last time the tuner used a regular GT tune as the baseline and had to add a ton fuel because it kept leaning out. I choose a Lethal Performance X pipe to go with the MAC LTs, I put some sound clips on Youtube if you want to hear what it sounds like.
1 - 20 of 22 Posts
