i got a 98 gt with forged high compr. pistons. would running boost hurt my motor?
You said you have high compression then you said you want high compression. If you don't have high compression yet and you are gonna build a motor and put boost to it then go with lower compression 8.5:1 or 9:1 with forged pistons and boost the hell out of it is what I would do.10.5 : 1. is what i want to get so ill be fine running about 8-10 psi? if not how much compression will be good with boost?
