1 - 5 of 5 Posts
I wanna SPRAY!
When I bought my car it was lowered but I never have tried to figure out whether the stock springs were cut or if the springs were aftermarket. Since I had the rear jacked up I checked out the springs and got this part number off them E5SC-5560-AA well I googled the number and ran accross some threads on other mustang forums but got nowhere since this second set of numbers that are on the springs 162559 never matched the numbers other members posted about. I saw replies ranging from fox springs to FRPP's but i'm not sure. If they are stock I can't see signs showing where they have been cut. If it matters any the springs are black and this number came off a rear spring. Thanks!
those are "B" springs
  • Like
Reactions: TaintedStang
they should have about a 1.25 drop on the front and around 1 or so inches on the rear, a little stiffer than stock. Not an aggressive spring but some what better than stock. Being a Ford spring, they are designed after a stock spring, they just made them with the drop in them and a little more pressure to them
I wanna SPRAY!
Thanks again for the info. I repped you for the help.
1 - 5 of 5 Posts
