1 - 6 of 6 Posts
hey guys just a question about the capabilities of the stock crank, rods, and pistons individually to know which order i should do them. i'll most likely doing all at once, but wanted to know for myself and my cousin who was thinking of upgrading pistons to run more boost. thanks joshua
the stock crank is fine for your goals.
the rods & pistons are where to upgrade & need to be done together.
okay thanks casper and hardhitter, just trying to figure out my build process. i've got suspension planned out, fuel and just curious about that. appreciate it again!
BYAHHHH!
give LoProRaceCars a call when you are ready to order..he will get you up.
dont forget a good oil pump(melling with billet gears) bearings, bolts and studs, ect
1 - 6 of 6 Posts
