1 - 16 of 16 Posts
No longer Maching out...
Hey guys, my car came with gears in it and the dealership had no idea what they were...
before I tuned my car it would stay around 1800 @ 55
but I put 18' wheels on it and changed the tire rev. per mile, I was thinking the gears seem like 3.73's but now when I'm driving 55 the tach says around 2k, and says 2500 @ 75...
What does it sound like to you?
I've already checked the tire size differences...but the new tires are 285/35-18
I wanna SPRAY!
I'm gonna guess 3.73's also. My 5 speed with 315/35-17's cruises around 2500rpm at 75mph also.
+1
Plus I'm pretty sure 4.10s are closer to 3k on the highway around that speed. Mine are 3.73s and that's what I get as well...
US Air Force (retired)
Tire sizes and speedometer corrections... It's really easy to find out. Put the car in neutral and chock the front tires. Jack up the back. Place a mark on the driveshaft and one on the tire. Turn the tire one complete revolution. Count the number of times the driveshaft goes around. 3 1/4 = 3/27 gears. 3 1/2 = 3.55 gears. 3 3/4 = 3.73 gears. And, a little over 4 turns is 4.10 gears.
This is the only way to know for sure without taking apart your differential.
Punching Throats
I have an the same rims and 285 in the rear and i'm pullin the same rpm's as you.......I was told i had stock gears from the 2nd owner.....WTF!!!!
The motive 3.90 aren't by Ford Racing which could be why it's stumping the mechanics. Also they require special instructions to be installed properly otherwise you can end up with a bad gear whine... while you're testing the driveshaft check for just under 4 turns. I'm curious :p
Discussion Starter #11
who the hell knows man...the way I'm thinking is that there is no way my car should be turning 2k at 55-60 with the stock gears
Could be 3.55's since the rmps went up after it was tuned to 3.73's
Discussion Starter #13
I never tried that...I could try the 3.55's tune
I'm just getting tired of messing with the tuner lol
You could always take out the differential, it's stamped right on the top of the pinion
Discussion Starter #16
haha...I'm pretty sure there's not an eaton rear end in it! lol
I'll check it out tho
1 - 16 of 16 Posts
