1 - 20 of 22 Posts
Hey guys, so i just had longtube headers put in and while pulling into the exhaust shop the guy asked why my car was smoking. I really thought nothing of it but now that the headers and X pipe are on my car is smoking profusely out of the passenger side exahust.
I dont really notice it when im on the highway or anything but i was just reversing out of a parking spot and a bunch of smoke came into the cab from the passenger side.
so i went out front of my house and had my gf sit in the drivers seat and give it some gas and sure enough quite a bit of smoke started pouring out.
My car has a 96 block with a PI swap. 140k miles on the engine.
Im sure the car has been doing this for a while but now i have the headers with an off road x pipe its ALOT more noticeable.
I could take a video could anyone help me with posting it on here?
EDIT: also for some more info, i do regular maintainence, mobil1 full synthetic, regular tune ups. warm up the engine before driving etc.
I wanna SPRAY!
What color is the smoke? Have you noticed the car using oil? Maybe oils inside the new exhaust are burning off and that's what your seeing. Another thing also, since you have an x-pipe their is no way to tell which bank the smoke could be coming from since both sides are joinging together at the midpipe and entering the catback.
Discussion Starter #3 (Edited)
it seems to be white smoke and it doesnt come out at idle it only comes when i give it throttle. I went out and bought a compression tester so i figured ill start with that and go from there.
also it smells almost EXACTLY like what i smelt when they were welding my exhaust up, not a sweet burnt coolant smell like almost a burnt metal smell.
anyone else have any input?
edit: also the car uses a TINY bit of oil but nothing noticeable inbetween oil changed. i dont ever have to top it off or anything like that
it is comming in the CAB?
mine smokes a bit from passenger side but its in the engine bay. i think my valve cover is leaking or something causing the smoke from headers but not too sure about smoke in cab. get a video if you can
Weird i just went out and checked the oil, and the oil looks to be brand new like always but it seems alot lower than where it should be. bout a quart low and it never burned that much before.
hmnnnnnnnnn
also the day i had the x pipe finished i was driving and i heard a huge POP and my engine stumbled a bit so i pulled in the gas station to check it out and nothing seemed wrong, turned it off started it and runs fine. MIND YOU the car still runs great right now just that smoke is bugging me cause i dont want a small problem to get worse.
i know this issue might be completely unrelated but just wanted to give yah guys as much info as possible regarding the situation.
about to perform a compression test when my father decided to come over and give me a hand.
I wanna SPRAY!
White smoke does not indicate oil burning.
well what does white smoke indicate???? one liners dont help much friend! i do appreciate your input though
I wanna SPRAY!
Well the only two liquids inside the motor is the oil and coolant, so if you take one out of the equation then you only have one left. :D If your coolant level isn't dropping or the coolant system isn't getting pressurized then a head gasket failure should be ruled out.
Edit: For future reference White Smoke=Coolant,Blue Smoke= Burning Oil,Black Smoke= Unburnt fuel
Discussion Starter #10
k guys so i just did a compression test (for my first time ever) all cylinders check out at 95-100, im sure that sounds a bit lower than the ones ive seen here BUT i attribute that to the cheap chinese tester i borrowed so as long as there wasnt any big difference between the cylinders i figure im good.
so upon further inspection the smoke seems to be leaving alot of moisture on my side pipes and doesnt come out while driving but after idling for a bit it seems to build up in the exhaust and burn off when i give it throttle
So ive got to figure out what would cause excessive condensation in the exhaust system? or what. also guys im sure i stated this but i have brand new long tube pacesetters and x pipe installed.
Discussion Starter #11
could it be that my car is just running rich as **** with the new headers and x pipe and that a retune is in order?
Discussion Starter #12
just talked to my mech and he says its normal for not having cats, anyone concur with that?
My guess would be you're burning oil which isn't normal. Head gasket maybe?
I say it could be a coinsidence that's totally unrelated to the install of the headers....... Maybe something wrong is happening inside the engine... For what ever reason when I work on my car, something unrelated needs replacing
I wanna SPRAY!
I think your just over reacting man, If the car isn't emitting a cloud of smoke behind it or running bad then I would just go on with life. If I rev my motor hard while it's in neutral it will puff a little white smoke sometimes but it's so little that you really gotta look to even notice. If you think it's something major then make a video for us.
lol everytime i work on mine nothing goes according to plan :mad:
my car does it too occasionally. and the a/f is right (maybe slightly rich) and the car runs fine. my buddies cobra does it too and it has a engine with less than 10k on it...i think yours could be running a little rich
MM Official Sammich Maker
I know when I was working at the local part's store all our exhaust would come in with a oil substance on it to keep it from rusting, and same with my bbk o/r x pipe and it gave a little smoke but burnt off soon enough.
Unless your having some noticable smoke all the time or it's running horrible I wouldn't be too concerned about it.
when i got my o/r h pipe i noticed that my car "smokes" a lot more than it did before
the exhaust is just a bit whiter and the fumes are easier to see without cats
Discussion Starter #20
yeah it passed the compression test so im not gonna go worrying too much, it runs awesome and pulls really nicely for a 4.6 so i guess ill clean up everything real nice when i get these hi tech stage 2s put in.
just gonna drive it and not worry about it too much but keep an eye on it, dont get why it would get alot of "wet" looking stuff insiide my side pipe, since you can see into it easily you can tell some type of condensation is happening on the inside of the tip
1 - 20 of 22 Posts
