1 - 20 of 26 Posts
auto, 5 speed, thanks for being about as vague as possible
sorry guys its a 5 speed basiclly stock motor it doesent happen all the time but some times ill be pulling up to a light or somthing and the rpms drop very low around 500 and it will stay running sometimes it just stalls
Admanistrator
This happened in my jeep. It could be that the )2 sensors are reading that it's running rich, so it cuts back the fuel supply, which cuts the car off.
Could be something else though...
its the thing on the throttlebody that looks like a little hair spray can with an electric plug going into it, 2 bolts hold it on
Free Mouth Hugs
Push in the clutch. Problem fixed. :)
Do all the steps in the link above and then see how it goes.
How does your fuel pump sound? Does it sound like it's RPM's drop also, I had one dropping pressure after a run on the highway and the ground was corroded causing the pump to slow down enough.
1 - 20 of 26 Posts
