1 - 8 of 8 Posts
I bought some new slicks an put them on an went to go crank it but it won't start we thought maybe it was the fuel pump but no so we checked all fuses an still no so does any have any ideas
a.k.a. Racecougar
It won't crank or it won't start? If it won't crank, you should be looking at your battery, connections, and starter. If it cranks but won't start, check that your fuel pump is priming when the key is turned to "ON". If it isn't priming, check the inertia switch. If it is priming, then my money would be on the crank sensor.
It is cranking but not starting the inertia switch is fine an come to find out today the injectors are not firing so could this mean the computer is bad
a.k.a. Racecougar
It's gettin fire to the plugs just not the injectors
nope it was the key
1 - 8 of 8 Posts
