1 - 20 of 44 Posts
Ok. I went out to leave for work this morning and my car isn't starting. All my accessories work (tested radio, interior lights, headlights). When I try to start it, it seems to crank and my radio comes on, but then my battery light comes on and my check engine light comes on as well. Any thoughts?
2001 v6 automatic
when i start it if i hit the gas i can rev the engine, but when i let off then my rpms go all the way down and my battery light and cel come on and it dies...haven't noticed any dimming of lights or headlights
i had an issue previously where they replaced my idle air bypass valve, fuel filter, and flushed my fuel system....think that is clogged up again somehow?
well i was thinking maybe alternater...i'm at 67000 miles currently so it's getting to be about that time...i haven't noticed any of my lights dimming though
or would i have to crank it until my battery got low for my lights to dim?
automatic
MM's Resident Ricer
so it will rev but not turn over? does it crank start to idle and die out
Discussion Starter · #12 ·
well from just turning the key, it won't idle at all. once i let off the key it just dies and battery light and cel come on....if when turning the key i step on the gas i can rev the engine, but it will die right away again when i let off the accelerator
MM's Resident Ricer
can you hear denotation when you rev while starting it? and does just the bat and cel light come on or all of them?
Discussion Starter · #14 ·
just the battery and cel come on...when i rev it i believe it is detonating, but it still doesn't sound quite like it normally does
Discussion Starter · #16 ·
well i haven't actually tried to go anywhere...i suspect i might be able to move it a little if i had to...if i step on the gas while turning the key i can rev the engine and as long as i keep revving it my trouble lights don't come on...it dies immediately though when i let off the gas then the trouble lights come on
edit: it won't start just turning the key...it will try but won't turn over on its own..tries to start then won't and bat light and cel come on
Sounds like the IAC went bad. That's your Idle Air Control sensor.
When it's running with your foot on the accelerator, how does it run? Smooth without any odd noises?
Do you notice any smells, like a heavy smell of gas from the exhaust?
MM's Resident Ricer
its your battery if you have denotation if you dont suspect IAC
Discussion Starter · #19 ·
IAC connects to upper intake correct? if so, that has been replaced about a year ago...if that is bad again there has to be something else causing it i would imagine
Discussion Starter · #20 ·
it could still be battery even though all my accessories work w/o the car running? i can turn on interior lights and headlights and can run the radio as well
1 - 20 of 44 Posts
