I mean the past several weeks i've been researching my ass off about this stuff. but i've got a lot of beginner questions
what are the top 3 brands to use?
Menzerna, Chemical Guys, Mothers
how do you properly clean dirty mf cloths, 100% cotton terry towels, brushes, sponges, pads
GEt some MicroRestore microfiber detergent or Tide Free and Gentle
how can you polish and wax in the sun? dont you do one section at a time and then wipe off?
I never polish in the sun I alway polish in the garage with 1000 watt halogen lights to see the defects. I also never wax or apply a sealant in the sun only is the shade or when the sun is setting.
what are common things people do, that you shouldnt do
Improper washing techniques, go to the detail stickies and learn the proper way. 3BM with grit guards, quality microfibers, detail spray, blower, and soap
what are uncommon things people do, that you should do
Use a blower to dry your car, use detail spray as a drying aid, wash from top to bottom rinsing each panel as you go. Use a foam gun or foam cannon to foam down your ride even before you start the wash. Wash in straight lines, apply sealants in straight lines, Use IPA before applying a wax or a sealant.
opinions on turtlewax, black magic, maguiars, CG, Adam's, or any other companys/products
Adams, CG, Meguiars, Menzerna, Uber, Mothers, Carpro, Optimum, etc.
is there anytime you can't claybar? also isn't it up down left right motions and not circular? dont you just lube and kneed clay in order to eliminate any potential problems
I would not use the clay right after you wax or seal, I know that sounds stupid and it is, but you would be surprised at what people do. clay in straight lines and use plenty of lube.
what are some necessary tools to detail
Check out the detailing stickies
average time to effectively detail
depends on you and how detailed you want to go
average price for a good detail
depends on your market and depends on what is included in the service and depends on how good the detailer is
looking back on what your detailing career what have you learned so far that you wish you knew when you started
how to wash my car correctly.
i have a ton of other questions but i'll stop there, i really appreciate any feedback that's given
