Your in California its illegal and you wont pass smog......................
or kill the engine before u come to a stop and coast for a little bit.there's lots of people in CA that run test pipes, just a big risk... $2,000 ticket if you're caught with non-factory cats (even hi-flows), and you would have to put the stock midpipe back in before getting SMOG'd. It's all up to you, just remember if you're getting pulled over, kill the engine as soon as you stop so theres less of a chance of the cop smelling your exhaust when he/she walks up to your car.
yea but that could be pretty noticeable if the car is loudor kill the engine before u come to a stop and coast for a little bit.
It might be cheaper now but lets say what the pypes O/R X pipe is what $179.99 at Brenspeed? Yea good price ok, but when you get caught that cheap $180 part just became an expensive $2180.00 dollar part........just a thoughti also heard that you would have to pre tune your engin due to the engine runs off the sensors in the cats.. blah blah blah, idk my friend said this and i was just courious cuz he knows a lot about cars. im awear of all the riskes, but O/R is soooooo much cheaper and i love the sound
very good point hahahIt might be cheaper now but lets say what the pypes O/R X pipe is what $179.99 at Brenspeed? Yea good price ok, but when you get caught that cheap $180 part just became an expensive $2180.00 dollar part........just a thought
its not 1000$ / per cat... and you will get state ref.t so all you have to do is put your stockers back on and go get inspected.. although when they inspect you for that theyll inspect you for everything else tooIt might be cheaper now but lets say what the pypes O/R X pipe is what $179.99 at Brenspeed? Yea good price ok, but when you get caught that cheap $180 part just became an expensive $2180.00 dollar part........just a thought
He's wrong but kinda right. The engine does not run off the post cat o2 sensors (the ones in the cats). Nor do those sensors have any effect on drivability at all. The primary o2s are used for fuel control, and a problem with them can cause drivability issues. The secondary o2s are only used to monitor catalyst efficiency. So without cats you will get a check engine light with codes P0420 and probably P0421 for banks 1 and 2 catalyst efficiency below threshold, but there will be no driving problem. The tune is used to turn off the MIL for you, just so you don't have to look at it. Most tunes you will see that do this will still not pass the OBD2 monitor test because it disables the o2, o2 heater, and cat monitors. Tuners can make tunes that will force the monitors to pass, but good luck getting one to do it.i also heard that you would have to pre tune your engin due to the engine runs off the sensors in the cats.. blah blah blah, idk my friend said this and i was just courious cuz he knows a lot about cars. im awear of all the riskes, but O/R is soooooo much cheaper and i love the sound
I thought you got pulled over in your V6 for no reason only because it was blacked out before.i am gonna try it since my mid pipe came with delete tubes.. and you have what.. 2 more years until smog.. your good and cops will only stop you if you drive like an asshole.. as long as your driving nice and legal they wont give you ****..
Honestly, I've never heard of a tuner not working with you to pass smog.Tuners can make tunes that will force the monitors to pass, but good luck getting one to do it.
