1 - 8 of 8 Posts
'99 mustang,
CEL is displayed, scanned it
no codes are displayed.
car wont start
it will turn over.
what do i do.???????????
desperate
ANYTHING APPRECIATED!!!!thanks
Billy Weston
Theft light blinking?
Fuel pressure?
spark?
compression?
will the car start with the gas pedal depressed?
Fuel pressure?
spark?
compression?
theft lght blinks when the car is off, when key is on its turns off.
idk about the fuel pressure or spark
and no the car will not start doing anything.
ive sprayed starter fluid in the intake, it just turns over for days.
Billy Weston
What were you using to pull codes?
Billy Weston
Datalog the car and check the fuel rail pressure sensor. Pull a coil and plug and sit the end of the plug on something metal. Turn the car over and check for spark.
harbor freight sells a cheap fuel pressure gauge --- i used it about 10-15 times before it failed but it helped me diaganose the problems on 3 cars over a year or so.
1 - 8 of 8 Posts
