1 - 10 of 10 Posts
amateur adult film star
i need to remove the center console on my 99 gt with a stick how do i do this where are all the screws at
there are 2 screws in the arm rest you need to pop off the radio bezel when you get that off theres 2 more srews theres a big plug on the left side unplug it pull e brake up that should be all
Radio bezel is simple. try to seperate the top end from the dash with your fingers and pry it off slowly. it just clips on. same thing with the shifter bezel ( which should be removed first). Then there are bolts in the arm rest. those come off and all that plastic crap should pull out. ( i think this is correct but I'd have to check my repair manual for the exacts ) .
sweet doesn't sound hard
1 - 10 of 10 Posts
