1 - 20 of 99 Posts
So I figured I would join the party with all the turbo builds going on. The car has been down since September of 2014. Im getting ready to start the installing everything to get it back on the road again. Here is a list of what's going on.
Engine ( built and on stand)
fully forged shortblock
mhs stage 3 heads
cms stage 2.5 turbo cams
Edelbrock intake
6061 intake
Turbo kit (just haven't picked turbo out yet)
CG T6 turbo hotside
on3 cold side
turbo charger leaning towards work turbo chargers turbo
dual 40 mm wastegates
Transmission (ordered should be here in 2wks)
FB performance 4r70w with lockup and transbrake
UCC converter
Fuel
Glenn's performance sumped tank
triple walbro 392
Areomotive FP
DeatschWerks 78 lbs injectors
I wasn't going to do the transmission until this winter but FB was having a sale . There is a few other things going into build like abs delete and batery relocation. Like to hear thoughts and opinions of the building. It's supposed to be done by end of May just got to get my buddy motivated to finish it.
Discussion Starter #2
Thought I would add some pictures of the old turbo set up and the carnage of the stock block
This is what happens when you ask your buddy to fuel the car on the trailer while you go take a piss and he puts 87 instead of 93 in the tank. Then takes 16 months to fess up.
Few pieces in oil pan
Here is old turbo set up
Not much to update
but did get a delivery today can anybody guess whats in the barrel
Super Moderator
Nice to see you getting it done.
I am really at my buddies mercy. He has my car pulled apart to were I cant move it to another shop. I literary have over 15k in parts waiting to be installed. Its not all his fault as I have to take some of the blame.
Freddy Brown has a strange way of shipping transmissions.
Got a little done this week got the tank pulled. Going to try to get glenns performance tank installed next week and fuel line s run
While the tanks out going to install team z upper and lowers. Also got the transmission almost out. Going to replace it with built FB 4r70w.
Super Moderator
Was you able to get your old fuel canisters out of the old tank?
Are you asking about the evap system ? I haven't pulled it yet but I talked to Glenn yesterday and he told me to use heat gun and lots of WD 40 on it.
he told me one of the pieces is no longer produced and I need to be very careful removing it.
that evap stuff is a ****ing nightmare if you break the big canister.
---------- Post added at 05:32 PM ---------- Previous post was at 05:30 PM ----------
i really wish somebody would come up with a good aftermarket evap system/tank vent thats easily adaptable to anything.
Super Moderator
I cut my EVAP out, its a pain in the ass. they don't even make the rubber gasket anymore.
Discussion Starter #13
You have a Glenn's performance tank? Did you try any of the was Glenn recommends removing them. Just trying to find out if they work or if I'm going to be cussing.
---------- Post added at 08:17 PM ---------- Previous post was at 08:14 PM ----------
Sub'd for this. Looking good!
Thanks been on vacation and my buddy just left on vacation so not much is getting done the next couple weeks
Super Moderator
The best way to remove them is to cut them out and work your way in cutting it.
Discussion Starter #15
What did you use to cut it out. I would be worried about creating a spark. Definitely wouldn't use the plasma cutter lol.
Super Moderator
I used a angle grinder on one tank I used C02 and the other tank was so old it didn't have any more fuel or fumes in it.
Discussion Starter #17
Going to try to get them out tomorrow. Going to try wd40 and heat gun and have some heavy duty tin snips as backup. Did you just reuse the old gaskets?
Super Moderator
I couldn't find any new gaskets anywhere.
Discussion Starter #19
Tackled the evap system today and it wasn't as bad as I was expecting. Took about 30 min to remove both canister. There is definitely a trick to doing it. First thing is not to try this by yourself or you will break it. It took equal pressure from both sides to get it to raise up high enough until you hit the lip on the canister. When it hit the lip we couldn't get it past it and you are limited to the amount prying up you can do without breaking it. This is were the heat gun and WD40 comes in applied wd40 around the canister and rubber gasket and a little heat to the metal around canister and then applied a little pressure and it popped right out.
Here is new tank with rubber gaskets in.
Here is evap system in the tank
Discussion Starter #20
Well got a little more done. Got the transmission out and mounted the pumps on the tank cover.
Next on the list is the install of the the tank , fuel lines and battery relocation. I want to run track legal relocation but I'm looking for ideas of how to run the disconnect out the back of the car. I have seen a few come out though the tail light but don't want to do it that way. If anybody has any suggestions that would be appreciated.
1 - 20 of 99 Posts
