21 - 40 of 99 Posts
Man thats coming along very nice, as far as the relocation and the disconnect switch, I've always liked my buddys idea. He used a oldsmobile flip down license plate, drilled a hole behind it to mount the switch. So all he had to do was flip down the plate at the track when needed it and flip it back up out on the street no one ever new it was back there.
Looking great.
Here is my switch.
Discussion Starter #23
Thanks how did he deal with lifting the trunk?
---------- Post added at 09:36 PM ---------- Previous post was at 09:34 PM ----------
Looking great.
Here is my switch.
Thanks. I was thinking that might be the way I'm going to have to do it. Did you run your cables under the car or inside?
They are under it.
Discussion Starter #25
That's the way I'm going to run mine . We are going to run the hot wire in 5/8 heater hose for added protection.
what fuel pumps are you using? i currently have a single magnafuel 750 external pump and its loud as hell. im thinking of doing something like what you did
He ran the wires inside the car and underneath the trunk lid. Gave himself a little slack to open the trunk with out stretching the wires.
Dont get me wrong it involved alot more work and cable but came out pretty nice.
Discussion Starter #28
They are walbro 392's. The setup is really overkill but I got a great deal on it. I don't know if you seen I had a better luck removing the evap canister from the tank then most do.
Discussion Starter #29
Went by the shop today to look at were to mount switch .Like the idea of running extra cables so the trunk can be raised . One of the fabricators came up with the idea of using the ford emblem on the trunk as the switch handle .He said he can mount it behind the emblem leaving it almost flush then making sone mounting hardware to attach the emblem. It will be kind of stealth looking except for the on/off he plans on airbrush on the trunk lid.
Discussion Starter #30
Not much to update decided to put installing fuel system install off to install a 8pt rollbar. Ordered Rhodes race cars 8 point cage. Should be ready to test fit it shortly .
Starting to pull the interior but it's been so dam hot hard to work on it for long periods of time.
Just have carpet to pull and a few plastic to remove
---------- Post added at 07:45 PM ---------- Previous post was at 07:23 PM ----------
I will be installing subframe connectors a the same time. We only have a 2 post lift so we are thinking installing the roll bar with all 4 wheels on the ground first. Then installing the subframes on the lift. We are hoping this will limit the body flexing on the lift. Will this work.
Discussion Starter #31
So I had to put this project on hold for a little bit due to spinning a bearing in my 87 T Type. I have finished that project so it's time to get back on this again. I moved the car to another shop to get this thing going.
They are going to weld cage in subframe connectors battery relocation and do fuel system. They got right to welding the cage in
https://flic.kr/p/WA72SR
https://www.flickr.com/gp/[email protected]/HV29io
Sorry for links haven't found out how to post images with flickr
Nice! Cage or rollbar?
Discussion Starter #34
Its an 8 point just finished welding it in. Been fighting with this new file sharing program this a rhodes racing cage and it fit great.
That will get you to 10 flat and 134mph at a nhra track.
Discussion Starter #36
Started the battery relocation today
Had wanted to put switch in different location but this was most practical place to put it
Discussion Starter #37
Started to button up motor today. Can I install edelbrock intake and C&G headers before dropping it in
Discussion Starter #38
Finished battery relocation had to redo it because first way we wired it up it just killed the ground instead of the power.
Discussion Starter #39
With the battery relocation done it's on to wiring up the fuel pumps. Installed the fuse block with 30 amp fues. Nice block has 6 circuits that can be run off it.
Only got 2 of the 3 relays in the 3 one should be here shortly .
Got to 2 wires run up front for the hobbs switches. The first hobbs switch will turn on the 2nd pump at 5 psi and the other hobbs switch will turn on 3rd pump at 10psi. Hopefully this will help keep the fuel a little cooler
Hopefully will have tank installed and plumbed up by the end of the week
Looking good.
21 - 40 of 99 Posts
