1 - 8 of 8 Posts
3v reppin'
My car topped forty thousand miles the other day. I'm figuring it's about time to start thinking about changing out my plugs. Not sure what plugs to get or if it makes a difference.
Looking for some advice. My car is N/A and will remain that way. Any suggestions?
Also, is there any benefit to upgrading the coils? I'm clueless.:eek:
I have been dreading this, mine is at 32,000.
Autolite HT1s or Brisk 3V17S.
I know the Brisk are a one piece design, that's what I run, I don't know if the HT1's are one piece or two.
Nasty, for some reason I thought you weren't a big fan of the Brisk plugs. Maybe I'm getting you mixed up with someone else, all you round eyes look the same.
Make sure you follow the TSB for removing plugs to a T, don't just go and try to pull them off and end up with a cracked plug in your head.
Resident Utahrd
Hmm...so, if I first got my car at 21.5k miles or so, and I'm at almost 49k miles now...should I be swapping plugs, too? :banghead
Being N/A, probably not, however, I'd pull them out just to clean off the carbon build-up and avoid that problem in the future.
1 - 8 of 8 Posts
