1 - 14 of 14 Posts
im about to change my springs i have the eibach sportline kit. Just wondering how had it is to get the stock springs out? Like will i need to compress them or can i pry them out?
rear springs should fall right out when you drop the rear-end, and have a pry-bar hand when doing the front
hmm seems pretty simple i will also be removing the rear end and changing all the control arms rear struts and removing the quad shock so its gonna be a little more work but same idea... thanks guys
mm's nitrous mod
control arms are easy and the rear shocks arent bad either. to remove the strut assembly, loosen the strut bolt and nuts before the car is jacked up. after cars is jacked up be sure to remove brake calipers, sway bar, and abs line before you start pulling the strut out. then put a jack under the control arm and jack it up to where the bolt and muts are off of the strut tower. there should be no stress on them what so ever and should be able to remove the nuts and bolt by hand.
Discussion Starter · #9 · (Edited)
do u run your sway bars? I was thinking of taking them out while in doing all this? How is streeability like that? and i will be removing the quad shock what do u think of that will FRPP upper control arms and boxed lowers?
make sure you get the pig tail in the right spot
mm's nitrous mod
yes and no. not at the track, and i dont put them back in till me and doc go out on out little "run". we have a little area that is nothing but twisties, and of course the sway bars are a little help. not to much difference in normal driving, noticable when runing hard in the corners. no need for the quads when doing upgraded control arms.
Just like all of the other guys said. It's fairly easy.
1 - 14 of 14 Posts
