1 - 16 of 16 Posts
Old timer
How often does this need to be changed? I have done a few vehicles before but never a mustang. Is it difficult? Where is the filter located? Anything else I need to know before I go and change it?
Doc
it's simple.
you just need a disconnect tool which is cheap.
the filter is attached to your gas tank under the car.
The UPS guy
its a bitch and a half to get to....its like behind the gas tank...and as far away out of ur arms reach as posssible lol
Doc
Tools/equipment needed
1. Motorcraft Fuel Filter--Part #FG-986B
2. 5/16Fuel Line-A/C Line Disconnect Tool. (Any autoparts store has them)
3. Flat head screw driver.
Directions
1. I first backed the car up onto my Rhino Ramps.
2. Disconnect the fuel inertia switch that is located in the trunk. This switch cuts off fuel
3. Next find the Schrader valve that is located by the throttle body, which is located at the end of the fuel rail towards the front of the car. It looks like a tire valve.
4. Once the Schrader valve is located unscrew the cap of the Schrader valve and use a small screwdriver or something to release the fuel pressure. This is much like letting air out of a tire....just press down and it will release the pressure. I would recommend wrapping a shop rag or towell around the Schrader valve and whatever you use to release the pressure. Gas will shoot up, not a lot, but enough.
5. Once you have the inertia switch unplugged and fuel pressure relieved start the car and let it idle until there is no more fuel getting to through the lines, which will cause the car to die on it's own and should minimize the amount of fuel that is released when changing the filter.
6. Next unplug the battery. I didn't do this, but my car threw a code after unplugging the inertia switch and used my predator to clear it. I think unplugging the battery will reset the computer after plugging the inertia switch back in when finished.
7. Get under the car and locate the fuel filter, which is right behind the gas tank.
8. Unscrew and remove the clamp.
9. Pry the fuel filter out of the the housing, which will give you a little room to work with.
10. Then take the 5/16 fuel line disconnect tool and slide in on the fuel line and move it to the outside (away from the fuel filter).
11. Once you get the fuel line disconnect tool slid all the way in, then pull the fuel line off the filter. A little bit of gas will come out so have something on the ground to soak it up.....I used some cardboard that I had left over from moving. I would also suggest goggles so fuel can't get into your eyes. Not a lot of fuel came out when I did this, but you never know.
12. Re-connect the fuel lines to the filter, but make sure the arrow on the filter is pointing toward the engine side of the fuel line.
13. Slide the filter back into the housing and put the clamp around the filter.
14. Re-connect the inertia switch
15. Re-connect the battery
16. Make sure to put the Schrader cap back on.
17. Put the key in the ignition and turn it to the on position and leave it for a few second, but do not start the car. Do that a few time to allow fuel pressure to build back up.
18. Check for any leaks.
19. Start the car and your done
its really simple. im starting to do mine every third oil change. but my car is modded pretty good with an aggressive tune so thats why i change mine so much.
on an IRS the fuel filter is tucked way up in there and no its not fun
N/A 4v Guru
I change my filter once a year. Like HMUSN said, its easy. Takes me like 5 minutes start to finish. maybe 10 if I use the ramps instead of mueh jack. And yes its worth it.
Retired MM Ninjas
I usually change my gasoline powered vehicles once to twice a year or every 30k mi. Diesels are every 7500mi to 10k or every 2-3 months.
I do this every spring just because I want something to do when it gets nice out. I enjoy it.
Fuel is going to spill a little bit, be ready for that. It's really simple, just use some ramps and you're set.
I don't even have the disconnector tool. Fuel filter and flathead screwdriver is all I need.
The Mean Green
I do mine about every 30k miles. On the cobras its kind of a bitch do to the IRS. If ya got the right tool, skinny arms lol and some patience its not a big deal.
1 - 16 of 16 Posts
