1 - 20 of 38 Posts
So, i finally have the time to change my oil this weekend and im gonna go synthetic. is there anything different i need to do when i change the oil or is it just like a normal oil change? and what is the recommended brand? thanks
ok, and is there only one grade of oil for synthetic or is it like regular with 5w20 adn so on
i actually recommend 5W30, ive found in a few cases on these motors 0W20, and 5W20, which is pretty much the same thing will seem past the rings a little.
you can't really go rong with castrol, amsoil, or mobil 1
thanks guys. so 5w 30 the safest bet or should i stick to 5w20. my motor has just under 40k
royal purple,amsoil or redline
i use mobil 1 or castrol syntec when i cant find it
N/A 4v Guru
I use Mobil 1 in my Mach. But Royal Purple at the parts store is getting almost as cheap as Mobil 1 now so I will probably be switching soon. Change out your diff. fluid with Royal Purple while you are under there.
so is it bad when switching form conv. to synth?
i heard that all the build up starts to break down once you switch and then u got all that crap in ur engine
N/A 4v Guru
Run it for awhile then drop your pan and check it out and clean it. Doubt you will find anything in there though. Unless you have been using quaker state.
1 - 20 of 38 Posts
