1 - 20 of 21 Posts
Just wondering if anyone on here is running this?View the Mustang T/X Extreme 8.8 Axle Brace at http://www.cheperformance.com
This summer i plan on making a lot more passes at the drag strip than previous years. I will be running a Mickey Thompson slick.
My rear suspension right now consists of...
Che Lower Control Arms........ Not on the car yet
Tokico Blue shocks
GT coil cut 1/2 coil
Plan on ordering upper control arms, and sub frame connectors.
Its not much but its a start, so im wondering if this would help me out in the 60 FT and just help put power to the ground?
Im pretty sure casper has it.. He made a thread about it awhile back.. Im looking at getting the same thing, and i remember him saying it was very solid stuff and great quality.
The one he made a thread about is a little different, his is for revised lower control arms..... Im hoping he will pop his head in here.
yea him or jazzer..
!FACEPLATED!
I plan on running one eventually, just dont have the funds right now. It is a good thing to get. Unless you want to be like me and keep cracking welds on the axle tubes
BYAHHHH!
so it's stronger but does it help you hook??
BYAHHHH!
yes me too. I am going to do ever suspension mod this summer...but rear c.o's to hook on concrete
!FACEPLATED!
It keeps the axle tubes from flexing. holds them straight and gives them support. A must when running sticky tires
  • Like
Reactions: GreyWarrior07
Procrastinator
I dont care if it drops my 60ft, I have bent axles as is and if this brace helps keep my rear from busting then its worth it. Depending on how much the rear actually flexes I bet the brace can help out quite a bit. Of course if you are on street tires with no suspension work all it will be is added weight.
BYAHHHH!
mmm..so you still run the usual uppers, lowers, and ARB?
i have this part of it
would you bother welding the tubes on my rear? im probably going to be making around 350rwhp on street tires.
!FACEPLATED!
Unlike caspers that has the relocated lowers, this one has nothing to do towards the suspension, it is mainly just an axle brake to keep the tubes from flexing
I will always suggest welding the tubes no matter what kind of brace is on it
  • Like
Reactions: Goose!
I thought that was what you were going to say, my only issue is funds.
Does the rear have to be dis assembled for the welding?
BYAHHHH!
oh ok thanks man! I wont need that till a t-brake. Tried to rep ya but cant..ill get back to it later
1 - 20 of 21 Posts
