First of all, it's a pleasure to be a part of this site...I've enjoyed reading a number of threads on here! Quite informative!
Second, I'm truly at my wits end over here. I purchased a 2007 GT Mustang from the actual Ford Dealership that had been modified by the previous owner. I absolutely fell in love with it the second I test drove the car. I purchased it approximately 7 weeks ago and it's been in the Ford repair/service department for 6 weeks....yeeesh!
Forgive me that I don't fully understand all the Tech talk that you guys throw out in the forums, but I thought I'd try to convey what I know has been modified on the car (according to the Ford Dealership). The previous owner's modifications included 'Long' Headers, cold air intake, gear work, dual flow master exhaust, computer chip replacement, Hurst shifter, etc.
The first week I had it (and the minute I drove it off the lot) I noticed three significant problems. The check engine light came on/blinking and the car would slightly bog down every 5-10 minutes (ever so slightly) when I was in 3rd or 4th gear at about 2800 rpms. When this bogging down was noticed, the air conditioning would shut off and only blow room temperature air. This entire incident would only last 15-20 seconds (then the air conditioning would kick back on and 'unbog'). So I immediately took it back to Ford.
They immediately gave it an overhaul, changed the plugs, gave it a once around and thought it may be the Harmonizer/toner. They found that the previous owner had the wrong aftermarket harmonizer in there...so they replaced it. We thought the problem was fixed-Wrong! Car went back into the shop. I'm unsure of the exact codes, but they told me they thought it had something to do with the O2 sensors/the 8th cyclinder was getting a weird reading. They worked on it for another week and I ended up going on a ride along, with the service foreman, who said the problem was fixed (until I was able to recreate the %^$*#% problem on the freeway-twice in 8 miles). The check engine light came on, car bogged down ever so slightly, and the airconditioning compressor shut off...WTF?
After Ford decided to replace the entire computer/chip, they then decided to send it over to their professional Tuner/Dyno place where it has been on the Dyno for 7 days now. After tuning/reprogramming it for 5 days, they said it was running like a Swiss Army Watch...so we went on a test drive for 30 minutes. It DOES run like a champ, but after 20 minutes, BLAM, check engine light, bog down, air conditioning cuts out. Ford was P.O.ed that their Dyno place kept it for this long and didn't correct the original problem....and so it's been back at the Dyno place for the past 2 days.
I call Ford/Dyno place every single day for an update on what's going on. Again, I don't know the codes that are spewing out of this car, in regards to the check engine light, but what I do know is that they originally told me the codes were saying an O2 sensor problem that was messing with the 8 cyclinder...then the 3rd cyclinder...then their was a fuel/lean problem...blah, blah, blah. After reading all of your posts, and all of your suggestions on this site, it seems that the FORD/DYNO place has done all of this...and then redone it again to make sure they did it correctly the first time. (i.e. Tune,check all sensors,spark plugs,etc).
They informed me, yesterday, that they are opening the engine up today to check something with the Cams (I think). I've lost track of whats going on now. It concerns me that a Ford dealership and a profesional Dyno establishment can't diagnose such a problem. Did I buy a lemon? Give it to me straight, Doc?
~Any suggestions would be greatly appreciated...I'm just going to hand the 'responses' directly to the Service Manager.
~MaxSharp
~MaxSharp
