1 - 9 of 9 Posts
Discussion Starter #2
so i looked around and it says that it is either o2 sensor is shot or my cats are clogged... but the xpipe is brand new so i doubt the cats are clogged.
So what do you guys think i should do? just clear the code or hwo would i check the o2 sensors?
US Air Force (retired)
Catalytic Converter Effeciency Below Threshold (bank 1). I get its companion bank 2 code, P0430, about once every 6 months. I reset it and it doesn't come back for a while. I don't know why I get it I'm running long-tubes and the rear 02s are supposed to be turned off.
There is a ton of stuff that causes it including faulty injectors and spark plugs. I'd try reseting it to see if it comes back.
P0420 Error Code: Catalyst System Efficiency Below Threshold (Bank 1)
Troubleshooting P0420 Catalyst Code
  • Like
Reactions: bigboy05
alright guys i just turned that code off.. and then the car threw P1000 the obd systems arent ready it says.. im not sure hwats going on :eek:
1 - 9 of 9 Posts
