1 - 20 of 27 Posts
Dont know if it's the same for the mach, but when I put my cobra one on, I had to redrill/clearout some of the holes for the plastic push pins to fit through.
Some people like nuts and bolts instead of the push pins, but I havent had any problems yet with push pins.
Painters tape if you're worried about scratching your paint. If its not bendable, leave it in the sun for a bit.
i used 1/4" self tapping screws and it sucked it VERY tight!
make sure you flush it up at the front of the wheel opening and not with the front of the bumper, its supposed to sit back from the lead edge of the bumper. I did mine wrong the first time then wound up redrilling all the holes
before
after
but you probably knew that, it seems I'm the only one I've come across who didn't know
maybe I should have researched like your doing
mine came out like the ^too. I left it though as i didnt like it sitting up under the lip.
Penetration before detonation
+1. As soon as I get a chance, I'm drilling out the rivets that I put in and fixing it. I have like an inch on the driver's side missing from the bumper. That's what happens when you don't take the time to line it all up and do it right the first time!
yeah the self tappers do it nice.!
1 - 20 of 27 Posts
