1 - 12 of 12 Posts
Not A Regular Member
I'm tryin to install some under dash lights and I got the shifter bezel off no problem, unplugged the power, and now I can't figure out how the hell to get the cigarette lighter out to put my switch in. There's 2 little clips that look like they need to be pushed in to let the lighter slip out but they just don't go far enough in to let it out. And I don't want to try to force it through and end up cracking the bezel. Help me out guys, how the **** do I get this thing out?
Yeah I'm gonna have to go see what I can find to attach to the switch to make it sit in there nicely. I found out it would fit in the cigarette lighter if I gave it a good shove. I might just go buy another cigarette lighter with the clips, cut out the end (the part that's closed off), put the switch in, and run the wiring back through what's left of the cigarette lighter.
Discussion Starter · #11 ·
For the lights? Or from the wiring from the cigarette lighter? From the cigarette lighter I was simply using the power/ground it already had and attaching them to the switch power/ground prongs. Then attaching the ground from the lights to the ground from the switch and the load to the load prong. When they wouldn't like up I tried simply running the lights directly through the wires (which would mean they would be on all the time when the car is running) but they still didn't light up. I guess I should have tested the cigarette lighter before I even started :p
Oh, if I do recall for my under dash neons I ran the ground onto the frame of the car, grounding has always been my issue. you could tap into your fuse box as well, ive done that countless times on vehicals. Run the power wire off a slot in the fuse box and run the ground to the frame of the car.
1 - 12 of 12 Posts
