1 - 6 of 6 Posts
Ok so obviously i wash i wouldnormaly dry. Is that a completely nescary step if i am gonna clay bar and ipa wipe. Also for a ipa wipe does i need a spray ottlemor just put it on a towlemand wipe then dry off.
Yes, you need to throughly wash, then dry your car. you don't want the lubricating spray to catch a dirty water drop when you are clay baring.
Cool thats what i thought just curious
Also when claybaring a window do you use spray detailer. Probably a dumb question but kinda unsure never claybared a window.
Yup! You want to use the detailer/lubricant anytime you use the claybar. :) Don't be scared to use the detailer, either...the more the better. if the claybar gets dry against the paint, it'll scratch.
Wax on, Wax off
  1. Wash
  2. Dry
  3. Claybar
  4. IPA Wipe Down
Always use the Spray Detailer when using a claybar on ANY surface. Make sure theres plenty of it. The area needs to be well lubricated, or the bar will not glide. You don't want to use a lot of pressure either. Simply glide the bar over your paint with the weight of your hand.
IPA... Some mix 70% with water at 2:1. Personally, I leave it at full strength. Put it in a spray bottle. Wet down the area, wipe it down with one side of a MF, flip it over, buff dry.
1 - 6 of 6 Posts
