1 - 11 of 11 Posts
The soul stealing Ginger
I have Mac longtubes, H pipe, Catalytic Converters, and flowmaster 40s. Yesterday i seafoamed the car and noticed that the majority of the smoke was only coming out of the drivers side tail pipe. when i put my hand behind the passenger side there was not nearly as much exhaust coming out as the driver side, i do know that i have hit a few speedbumps and i think i came down ontop of my CATS a few times, im not sure but going to check for scrapes today. basically the question is should the exhaust be coming out equal on both sides or is more force exerted through the driver side pipes.:sorry
Discussion Starter #2
:(........bump
Ill have to check to see if mine is muffled, but other than that i have the same issue, but i have no codes running, p420 i believe is the code where i changed out a few things on the EGR system
I checked it yesterday after seafoaming, i tapped my inertia switch to spring it and when i did that it threw a code, inertia switch was the only thing reading.
if you have an H pipe then im guessing its a bit of both, more air will be coming out the drivers side, but it shouldn't be that noticable.
I would say its pretty noticeable. considering cutting off my CATS (no emissions tests here) to see about a different sound.
isk about cutting the cats... i heard you lose some mpg and it won't sound that great.
Discussion Starter #10
I used to have them gutted before but when i got the full exhaust setup i have no i opted for CATS again. well see, i would like to see what it sounds like CATless and if i dont like it i can always have new ones put back on.
1 - 11 of 11 Posts
