1 - 6 of 6 Posts
So I have a very obvious metallic clunk/clank coming from the front left side of my 96 Cobra that seems to be worst at slow to medium speeds over any sort of bump. Oddly enough as soon as I hit the brakes the sound will stop and resume when I let off. I recently replaced the struts, springs/isolators, sway bar end links, ball joints, and inner and outer tie rods but the problem still exists. Only original parts left up front are the bushings, brakes, strut mount, and hub assembly so I'm wondering if its one of those. Before I start throwing more money at this elusive problem figured I asked here to some more knowledgeable people on what your opinions are. And yes everything is torqued correctly and I didn't notice any obvious signs of issues while it was apart.
King Trashmouth
You more or less need to get it up in the air and see where there is any play. The fact it goes away with brake application makes me want to look at wheel bearings, or something of the sort. The usual approach is getting it up in the air, check for play by rocking the wheel top to bottom. That will indicate bad wheel bearing. Side to side is more tie rod. Ball joint is usually done by sticking a pry bar under the wheel and checking for a popping, but that's usually most noticeable when turning. For bushings you more or less need to disassemble them for a visual check or you might be able to get away with the pry bar technique in the fore to aft direction. If they're really shot you might be able to notice it by rocking the wheel side to side.
Had a vehicle that did that and it ended up being the bushings. Also had another vehicle and it was the strut mount. The vehicle with the bushing had miles on it so they needed replaced. The vehicle that had the issue with the strut mount was my wife's 2003 caravan and I think it was replaced four different time under the warranty. I was so glad to get rid of that vehicle.
I guess i should have checked the obvious before posting lol. It turned out it was the anti rattle tabs in the front left caliper. Ironically had a brand new hardware kit laying around for it so i was able to do both front. Fixed the problem perfectly. False alarm but thanks for the help.
6 Cylinduh, Really Bruh?
You can check my post history. I was battling a clanking noise extremely similar to this. I did everything. I mean everything. I was like wtf is going on! I changed every thing! I did every thing but.... the lower control arms. The freaking lower control arms were the culprit of my noise issue. The lower control arms come with rubber bushings from the factory. How did I miss this? My 2001 GT with factory rubber bushings in the lower control arms and I didn't think about it.
Long story short. I bought moog lower control arms. I pressed out the bullshit lower ball joints that use a lock but and pressed in moog problem solver ball joints that use an actual castle nut and fitting to grease it manually. Problem solved!
Hind sight is 20/20 But damn it is everything now new under there. When I took out the factory A arms the rubber bushings were shot. Cracked and hard as a rock. The moog replacements were soft and supple. I could have kicked myself for not thinking of this in the first place. I cross shopped Amazon and rock auto to get the best deals.
Amazon had the passenger side cheaper. Rock auto had the driver side cheaper. Amazon had the lower ball joints cheaper as a bundle of 2 after shipping. Go figure.
Sent from my SM-G920T1 using Tapatalk
1 - 6 of 6 Posts
