1 - 4 of 4 Posts
so i got a new stage three clutch kit about a month and a half ago. Never felt right since it was put in, and now i barely got it home today, and cant even get it to go into gear. My question is on the clutch fork there are two holes on it, and if i remember right you put it in the first then slide it into the second one closest to the bell-housing assembly. is this correct or is it supposed to be on the outside edge of the fork? when they gave it back it was on the outside, but i feel like it shouldn't be. please help with this one guys!
It should be in the outside hole (the smaller one). Do you have an after market cable and quadrant? Firewall adjuster?
yea i have an adjustable cable, and a aluminum quadrant. when i got it back it was very jerky and didn't feel like it was engaging how a clutch should.
is the outside one the one closer to the bellhouseing or the one farter away, im guessing farther away since u said outside, but i just want to be sure. thanks for the help tho.
1 - 4 of 4 Posts
