1 - 3 of 3 Posts
occasionally hearing noises when engaging clutch (releasing pedal)
sounds like metal rubbing?
usually happens in lower gears & usually in colder weather, but recently has been occurring in all gears & all weather
any ideas?
ive got the car up on jackstands right now while im doing some other things so if u have an idea let me know
car has about 57000 miles on it
¡ʇsnq ɹo uʍop ǝpısdn
does this happen when the clutch is fully engaged and always when its fully engaged? or is it while engaging??
could be your throw out bearing if its the first one... second one might mean that the fork that opperates the throw out could be acting up or a cable problem... OR you might have some issues with your flywheel and clutch ...
thanks for posting in the correct section :D
happens while it is engaging...id say about the last 1/4 when i let it out
1 - 3 of 3 Posts
