1 - 7 of 7 Posts
i just bought a 99gt, my second mustang, but it came with a drag pressure plate! 150 pounds and i plan to daily! :crying: i have no clue what flywheel i assume its stock, i was looking at the excedy stage 1 & 2 or the king cobra i dont want to replace the flywheel if possible, i plan on going fi about a year down the road, im going to rebuild around then. any imput is apreeciated
US Air Force (retired)
I've had good results with my Centerforce Dual Friction clutch and pressure plate.
King Trashmouth
The Centerforce Dual Friction I had was pretty grabby, but that's going back quite awhile.
For a very light, daily driver, if you want a stock feel the King Cobra is very popular. However if you're going to boost it later on, you'll probably exceed the grip of it.
A Spec stage 1 or 2 would probably fit the bill as well, depending on how much power you plan on putting down.
I put a Exedy Mach 400 Stage 2 on my Mustang and it feels about the same as stock if not lighter. Works nice and smooth. I plan on Supercharging so it should hold decent power. I suggest getting a new flywheel for insurance. They're pretty cheap if just get a stock one on Rock auto.
I had the opposite experience. The Spec stage 1 I had installed never worked right and lasted all of four months before I had to replace it. I almost had to stand on the clutch pedal to get it to the floor. My Centerforce is smooth as silk.
I replaced my clutch with the Exedy stage 2 and it grabs so much better and more quickly but still feel like stock.
+1 for Exedy
1 - 7 of 7 Posts
