So I replaced the clutch cable yesterday. The first time I started it up, gears went in like butter. After a few uses, it goes back to hard to put in. It's like the clutch doesnt engage right. When i go to push first in, it kinda wants to drive forward. It gives me a hard time putting into any gear from a stop. Like tried putting into 3rd first etc then to 1st but doesn't work. When I go to put into reverse it will sometimes go In smooth, other times it grinds or clumps going in. NONE OF THE GEARS GRIND DURING DRIVING and none grind going in except reverse OCCASIONALLY. If I'm rolling to a stop I can put every gear in just fine. Just from a dead stop I get problems
