1 - 3 of 3 Posts
Ok I've looked every where and can't find the answer, I can't seem to get my clutch adjusted correctly. I was told by a mechanic that the tob should be a little bit away from the fingers on the pressure plate, but when I adjust it like that it doesn't have a far enough pull to disengage the clutch. I've also read that the tob is supposed to ride the pp fingers all the time.
So which one is right?
Thank you
supposed to touch it, just take the slack outa the pedal. Any more itll be puttin pressure on it constantly and the clutch will get ruined
Alright thanks hatch, I ordered the firewall adjuster the other day and this is the only thing holding me up on driving it after my aod to t5 swap
1 - 3 of 3 Posts
