that's awesome, good numbers, and all that on 14 psi. really the cams are allowing you to make more power with less restriction. hence "lose psi". bet that thing pulls like a raped ape on the high end.
---------- Post added at 08:25 AM ---------- Previous post was at 08:23 AM ----------
you guys look at your Oats, do you look at them while cruising, or WOT?
With only a 6 rib belt I think an IW 10% overdrive pulley would have been nice. At this point switching to e85 and maybe turbo could happen in the next year or so.
With only a 6 rib belt I think an IW 10% underdrive pulley would have been nice. At this point switching to e85 and maybe turbo may be in the next year or so.
Nice! 14psi sounds right for your pulley setup. My V1 S makes 12.4psi with a 3.125 pulley. Si's with the same pulley setup as the old V1 S usually make 2 psi more.
Car has received a lot of cosmetic changes since then but still run strong for what it is. Finally tune was 605/535 on 16psi with a D1sc, 373 gear and TKO600 trans.
