1 - 20 of 20 Posts
tried google but maybe im searching wrong or did not have the exact answer that im looking for. what valve springs should i look into buying? (pref people that have these cams to chime in on what they used). then also what adjustable cam gears to get.
are those the beehive springs? i looked them up and it said the seat pressure is 93 @1.57
also did you guys get adjustable cam gears
I had stock gears that were degreed when they were on the car. And i also have comp behive springs just like gto1. Go to the cms website and see what they recommend. Or email jim cushman. He normally responds quickly
Cms stage 2 N/A cams
Trickflow spring kit (its like $170-$200)
2 TTY cam bolts
Stock cam gears
Just dropped in, not degreed
All ordered from cushmanmotorsports.com
Any PTV issues with the CMS Stage II's on stock pistons? I want a setup like yours Dave.
No, I have stock everything with cms stage 2 cams.
Just dropped in, spun over by hand to check for ptv and re assembled. Jim said most don't degree them althought its obvisouly preferred.
Discussion Starter #15
dave, did you get the trickflow 120lb kit or the 90lb?
Either the 120lb or 90lb will work
Full bolt on's + Cams made 285/315 WHP/WTQ
After LT's and electric water pump
Made 307WHP this run but final numbers were 305/333 WHP/WTQ
I was more talking about the LT's. The cams I knew would be needed.
1 - 20 of 20 Posts
