1 - 4 of 4 Posts
I will try to dyno after every most every mod.
Future mods include:
-1 3/4" primary headers
-Ported intake
-Spacer
-Accufab TB
-Cams
-Aluminum driveshaft
-Cobra R alt and hydraboost pulleys, WP pulley and a small diameter damper
I'll be using is a "loaded" dynojet for all tests.
For the dyno below the only power mods are:
96-98 Cobra intake cams installed at 107.5/112
Off road X-pipe/borlas/2.5" tailpipes
driveline mods:
Automatic trans with Circle D "2C" converter
4.10s
I added a Steeda small diameter damper, March hydraboost and water pump pulleys, and a 1/4" spacer. Did not retune, only dyno'd for numbers as we were short on time. The a/f for some reason was .1-.2 richer than the previous dynos and we encountered a voltage issue that caused a dip in power just under both 5k and 5.5k. Voltage output was 12.2-13.2 fromthe beginning of the run to 6350rpm. Peak power gain was a little over 7rwhp and max gain was 18rwhp at 6350rpm. Without a doubt, with the correct a/f peak tq would have also increased. Also, if taken above 6350rpm the hp gains would have continued to increase beyond 18rwhp.
Next up are SLP 1 3/4" primary long tubes, RAI (or CAI) and a the testing of a couple intake manifolds.
nice cant wait to see more results!
i've been thinking about the 98 cobra cams for my mach, what was your base line prior to the cams, about 275rwhp?
I bought the car as a roller and put the cams in before I installed the engine. The baseline numbers for this are in the first graph and the power mods were only a k&n filter and off road X.
I advanced the cams quite a bit because I wanted a broad powerband with good midrange rather than high peak numbers.
Next up are long tubes and the testing of a couple ported intakes.
The goal for this combo is 320rwhp with the stock cams which would be similar to a 340rw manual trans combo.
1 - 4 of 4 Posts
