1 - 6 of 6 Posts
not gettin any help from 4v guys so imma try 2v lol..
but wats the head gasket bolt torque specs n tightening order? and the main n rod cap torque specs? ( with arp bolts all thru motor ) and wats the best piston ring gap locations to set them at? thanks............ on a 01 cobra
Sloth for President
You know I heard if you add in more question marks you'll probably get a response faster.
Lol; Just wait, and ask clearly and logically, the people of MM try to think they have lives, so they'll periodically not be here 24/8
Cylinder head bolts DOHC (four valve Cobra, and Mach One)
--Step 1 28-31ft/lbs
--Step 2 Tighten additional 90 degrees
--Step 3 Tighten additional 90 degrees
The main cap bolts are 70 ft lbs, and rod caps are 30ft lbs.
The sequence goes similar to this. Each dot is a bolt on the head.
o o o o o converts to 7 5 1 3 10
o o o o o 9 4 2 6 8
I hope that helps man.
FYI you have to do that sequence 3 times and each step represents the time you do the sequence.
lol hhahaha yea true true^^^
n yea man it does thanks for the info
1 - 6 of 6 Posts
