1 - 20 of 80 Posts
they are different the termi tanks have 2 pumps and the tank is sumped so you don't have to worry about fuel not getting to the pumps on heavy accel or turns.
  • Like
Reactions: dcook_14
yeah, i think that was it sumped vs. non-sumped. wraitherlx you're getting reps for backing me up and having a damn nice avatar :)
thanks and :lol, oh and thanks for my 6th block back at you with the rep
You need a 03-04 cobra tank and pumps. The swap is super easy, it just bolts right in.
Cobra tank with sump
GT tank
The hardest part is swapping the blue plug things. They were in there good on my tank, but i did it without damaging them at all. It takes about 1hr.
lol.. you cant even tell the diff.. but ur gonna want too do the swap.. going lean under heavy accel sucks!
Discussion Starter · #12 · (Edited)
what are the minimum parts i need? can i just get another gt pump and wire it in with some kind of y connection to hook them together? can i wire 2 different pumps together say a focus pump and a gt pump? i know thats weird but just wondering
are u tlking about the the stock gt pumps?? or the ford gt pumps?
I would use the same pumps. Get the gates hose that is something like $5 a foot. I forget the model number, but regular fuel hose is not rated to be submersed. It has to be high pressure fuel injection hose too. Get a brass or SS Y fitting, hose clamps, etc, and solder and heat shrink the connections. Eliminate the PPRV too if you have not already. If you do not go with the sumped tank, never let it go below about 1/4 tank.
Discussion Starter · #16 ·
okay and do both pumps fit in the stock gt basket? how much will dual cobra pumps flow vs a ford gt? what would happen if i used different pumps?
the 03/04 cobra pumps flow like 390 i believe.. i dunno about the gt pumps
mm's nitrous mod
You don't need the tank, just the sending unit/pump assy. The tanks are the same.
wrong, tanks are different.
okay lets say that i want to do this as cheaply as possible.. can i fit 2 pumps in the gt tank with modification? the ford gt pump with bap is pegged
yes, but i still say something is wrong with your set up.
$5 a ft??? where at? i pay $30 a ft for the submersable hose.
1 - 20 of 80 Posts
