1 - 3 of 3 Posts
Quick? I hav a 94 cobra i parted out and i can use the t5/w Bellhouse to put behind my 377 going in my 84 coupe with a Ford racing aluminum drive shft. And i have a 91 t5 that can go back in but i dont remember if it was 100%. Has anyone put this or any SN trans in a fox???? I know they are i bit longer and it is hell finding a 93 cobra input shaft to swap shafts so thats out!!! and would the SN Cobra trans work with my centerfource clutch? NEED TO KNOW ASAP SO I WOULD KNOW TO SELL THE COBRA TRANS OR NOT....Thanks:confused:
Resident Know-it-all
As long as you use the bellhousing from the cobra too, it will work.
Well, it'll bolt in but then the clutch fork will hit his header tubes because of the different angle, or hit his H pipe. Just sell the cobra trans or call D and D and get a fox cobra input and swap the parts over. It's not rocket science but it takes a press and some skill to do. I think the inputs are around 150 or so new.
1 - 3 of 3 Posts
