Thanks, pepes, but I certainly DON'T know it all and limited on spring/strut/shock info. Will pass along what I can, but first head to the
Official Suspension Guide by our own ModMustang97GT for some good info.
I ran a set of 300# (f) and still run 200# (r) with Koni Yellows and was a good combo for street. I cannot speak to 1/4 mile use, but sure it would have been much too soft for AX. The ride was quiet comparable to the Saleen set-up prior to this one and was an improvement on rougher roads. Depending on the type of roads you have in your area, you may consider a stiffer set as I had lots of body roll and a fair amount of understeer this route. I didn't start AX untill after I went SLA up front, so cannot speak to the above with VERY aggressive driving. I still run the 200# CO's out back, but now run a MUCH heavier rear sway bar as I have stiffened up the front a bit. This did wonders for my understeer, so it is safe to say, that although nice ride and comfortable, the 300#/200# set-up is not going to be good for much more than the street.
Hopefully, The Good Reverend will chime in and add a bit more
Jazzer
