1 - 2 of 2 Posts
04 4.6 easiest coil pack, driver's front won't come out. Just spins. I tryed prying up with flat head and cant get it to catch and back out screw. Any ideas?
Had that same problem awhile back..Not sure if it was the right way but i used my dremal and cut head off removed COP and was lucky enough to have enough thread on top to use a nut for when i put COP back on .If you dont have enough thread you can heat the brass grommet thing the bolt goes in and pull it out and get a replacement or be able to secure one end while you back bolt..I say again dont know if its right way but worked for me..Im sure one of these fellas will chime in and from what ive read from some these guys they know what they are talking about..Good luck
1 - 2 of 2 Posts
