1 - 8 of 8 Posts
Purchased the Comp Cams Xtreme Energy XE270HR Cam for my '94 GT. I have the GT40P heads and upper/lower intake also. When installing my cam will i also need to change valve springs? Or can i just use the stock setup?
Discussion Starter · #2 ·
Intake Exhaust
Valve Lash: Hyd. Hyd.
Duration: 270 276
Duration @ .050" Lift: 218 224
Valve Lift: 0.544 0.544
Lobe Lift: 0.321 0.321
Valve Timing @ 0.05" Lift: Open Close
Intake: 27 BTDC 63 ABDC
Exhaust: 74 BBDC 22 ATDC
These are the specs for the cam. Also can i use the stock rockers? Ive read that stock are 1.6 and people have used 1.6 with this cam. jw how much more money im gonna have to spend on this
Resident Headbanger
That cam was designed for 1.7 ratio rockers and you'll definitely need to upgrade the valve springs. This isn't the time to cheap out and reuse stock rockers/springs.
1 - 8 of 8 Posts
