1 - 19 of 19 Posts
As the title says, this is pretty boring. I just thought I would throw it up in case someone searches for stock dyno runs to compare against.
The car is the one in my sig. There are just under 25k miles on it. Note that the SAE correction is 1.04, so I am getting the same 262-265 most guys are. Temperature was 85' F (probably upper 70's outside of the shop). Elevation is about 600'. Two pulls were done, with a ~10 minute cooldown between.
High-res version of the below is here. PM me for the original.
Video of the second pull:
Stock Dyno Pull 2
Welcome to the site and thanks for the info. I am hoping to get mine on the dyno this spring. Anyone know of and shops in S Ohio, N KY?
Thanks man! Only one way to go from there....UP:D
Good Info,and welcome to MM...I know Temps,and humidity changes the outcome of runs,but I'm just curious about the differences in Dyno's??? This is my baseline,and after CAI,and Flashtune.... View attachment 13412 Thanks....:eek:
Stock Dyno Pull 2
Great info with the dyno sheet and welcome to the site.
IBEATU
How do dyno's compare? What I mean, is what would be thi difference if he had gotten his done on a Mustang dyno?
Mustang dynos typically read lower than say a Dyno-Jet. A Mustang Dyno applies brakes to the drums to simulate a load on the vehicle. It is a more realistic number of the power you would have while driving down the road
Thanks Mike for verifying that,and refreshing my memory..I did read that in MM/FF:cool:
+1 if you want the more accurate hp numbers then a mustang or dynamic dyno's are for you. if you want to impress people with how much horsepower you have dynojet is what you want.
1 - 19 of 19 Posts
