1 - 4 of 4 Posts
ok so im in the middle of putting in this electric fan, ive got the relay half way wired, its just waiting for the batter to relay and relay to fan lines, but heres were te doubt comes in, i got the switch for inside the cab in and i started up the car, turned the switch on, put the ligght wire for my guages on it and it makes the car rumble at idle like its got a cam, and the lights on the guages flash, is the fan going to draw way to much?
The Razor's Edge
electric fans do draw alot.....do you have an electric water pump or a nice stereo? even so its worth the 10 hp or so you gain...
well i disconected the brake guage and i did the same thing i did as b4 and it didnt rumble, it started to snow real bad while i was putting it in so i had o stop, but all i gotta do is put the new fans on and run thier wires, worse come to worse ill just iono ill figure something out
1 - 4 of 4 Posts
